14 bolt question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hardcore, May 15, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    I've started looking for Dana60/14 bolt combo. The Dana 60 is a little tough. I've found a few 14 bolt full floaters but they are on late model trucks. (Mid 90's) Is there any difference. My truck has rear ABS and I guess there may be some conflict if GM changed the ABS system. Do I need to stick with 73-87 axles??? /forums/images/graemlins/1zhelp.gif
    Thanks,
    Corey
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    first off if you ever plan on swapping to rear disk brake you can't use those axles. im not sure on the wms on those but it MAY be different. and you would have to grind the spring perches off and weld new one on. as far as abs, ive never seen it hooked to the differential on a GM, only a ford
  3. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    WMS??? /forums/images/graemlins/confused.gif
    I did want to convert to rear disks. I didn't realize the spring perches were different. I guess I need to look for a 87 or earlier then. /forums/images/graemlins/blush.gif
    Corey
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    WMS=Wheel Mount Surface /forums/images/graemlins/wink.gif
