14 bolt questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 2cocky, Oct 8, 2001.
  1. 2cocky
    2cocky Registered Member
    Oct 7, 2001
    59
    Southern Maryland
    Ok I have a good deal {read free} lined up on a 14 bolt out of a 80 3/4ton pickup what i need to know is will it fit my 86 k5 the donor truck in a 2x4 with a six bolt pattern. ok guys help me out
    OOOPS....I THINK I JUST RAN OVER YOUR JEEP THING!!!!!
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    14 bolt FF came with 8 lug patterns only, used in C and K series pick-ups, 3/4 and 1 ton.
    14 bolt SF rears I don't think were offered as early as 1980, but the majority are 8 lug as well with some 6 lug SF's available in the late 80's. Majority found under 3/4 tons...with the 6 lug available in some 1/2 ton 4x4's in the late 80's and early 90's. The only other bolt pattern available for the 2 WD pick-ups was the 5 lug pattern for the half tons.
    If it is a 14 bolt FF from an 80 3/4 ton it will bolt up with very little effort. Spring pad width is the same and the shock mounts are in the correct position as well. You will need to use a hybrid U-joint, I can never remember the pn#, and the e-brake may need some mods to interface with your truck.
    Rene
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No 14 bolt full floater or 3/4 ton truck for that matter came with a 6 bolt pattern axle (not in this body style anyway). Look elsewhere.
    Tim
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Just to add, you might not need a conversion u-joint. Some half tons (like mine) came with a 1350 -u jointed rear driveshaft.
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'll second that on the factory 1/2 ton 1350 u-joint.
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  6. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    U-joint is NAPA part #447(about $30)
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
