14 bolt r&p master install kit
Discussion in 'The Garage' started by cegusman, Feb 11, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is all included in the kit? Why dothe kits cost so much more than the ones for other axles (dana 44 for example $75 vs. $145)? What is the cheapest you have found one for?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> They cost more because the bearings are huge and there's more of them. I think I paid $118 for mine when I bought all of my other axle stuff at the same time from Drivetrain Direct. </font color>
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Randys R &amp; P sold me mine for cheaper than that. I don't remember exactly how much, but it was cheaper than that.
    -- Mike
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I just called randys ring and pinion, and the best price he could give me was $131 plus shipping.
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    You should get both carrier bearings and races along w/ the two pinion tappered roller bearings/races and the pinion pilot cylindrical roller bearing / a crush sleeve / new ring gear bolts / pinion depth shims / pinion nut / pinion yoke seal / gear marking compound ( get the GM stuff - it is usually better ) a small tube of thread locker and a little brush / instuctions on gear set up and gear breakin .
    I think that the Dana kits are cheaper due to the fewer bearings / different style of shims and some of the parts in certain Dana axles are interchangable therefore makes them cheaper( supply &amp; demand )
