14-bolt ratio question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by doc70sub, Oct 18, 2002.
  1. doc70sub
    doc70sub 1/2 ton status
    Oct 8, 2000
    688
    Thomasville, NC
    Hey Guys,
    I brought home a 14-bolt van-width rear today for my Blazer. When I removed the cover, I counted 41 teeth on the ring, the ring had 41 & 10 stamped on it, as did the pinion. Is this a 4.10 axle? Thanks!
    Doc /forums/images/graemlins/k5.gif
  2. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    count the pinion just to be safe bust most likely yes. Its the ring gear teeth divided by the pinion teeth. So your pinion will have 10 teeth if it is 4.10.
  3. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Without a doubt its a 4.10... the third number should be the year it was manufactured.
  4. doc70sub
    Oct 8, 2000
    688
    Thomasville, NC
    Thanks guys!!
    D.
