14 bolt rear end Q
Discussion in 'The Garage' started by schmuck1124, Jun 16, 2005.
  1. schmuck1124
    schmuck1124 Registered Member
    Jun 4, 2005
    14
    ocala, fl
    i am putting a full-floater 14-bolt rear end in and am looking to change the drum to disc. a couple people have told me that all i need are calipers, rotors, brake pads, and the template, but i am wondering about the hub situation. i have a drum that i believe to contain the hub inside of it? it has a seal, and two bearings - are the seal and the two bearings the hub? if so, what do i need in addition to previous list to complete this transformation?any information i am most gracious for.
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    For the disk install on a 14BFF you need:
    Brackets:
    Hoses:
    ....as well as rotors and calipers.
    When assembled, it will look similiar to this:
    The hub is the part that the wheel mounts to. The rotor mounts to the backside of the hub as you can see in the pics.
    There is a really good write up here.
    Good luck! :D
  3. schmuck1124
    Jun 4, 2005
    14
    ocala, fl
    thank you!
    i am still a newb to most of this, and i really appreciate the pictures (that is a damn good idea too). a good friend of mine has converted to the 4-wheeler brotheren and is giving up on the big trucks (had a nice rig too....). thus i am inhereting a dana 44 HD front end, and a 14-bolt rear. i am not familiar with the ins and the outs, and was concerned that i would b coming up short - parts and cash. a picture truly is worth a thousand words, and a thousand thank yous. happy wheeling!
  4. jmd4x4
    jmd4x4 1/2 ton status
    Apr 4, 2005
    137
    Rosenberg TX
    What part # did you use for the brake hoses, or for what vehicle did you ordem them from? I am needing the brake hoses for my convertion and have to find out witch ones to get.
    thanks
    jmd
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I just got some from an 79' chevette.
  6. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    i second that!
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    And I'll third it.
