14 bolt rear end swap questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Jul 5, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    when changing my rear end to a 14 bolt will I have to change the brakes or anything? Will it bolt right in. I assume I would need to get u joints that will work for the 14ff. any help would be useful.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    do a search for 14 bolt swap... there are literally tons of posts here about it...
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    napa and such carries U joints with two sizes of caps, tell them 73-79 3/4 ton on one side and other side for whatever year and axle you had originally and they will hook you up with a U joint to do that, brakes no worries just connect hose/line at the block on the axle tube or diff cover bracket and bleed them out good.
  4. sasquatchhunter
    sasquatchhunter Newbie
    Jul 17, 2003
    I have a 1976 k5 with a 12 bolt rear end and I was going to switch it over to a 14 bolt. I was wondering if I could get a way with not replacing the drive line right now? Is it a must or can a drive it around with the old 12 bolt one? My friend said I would but he wasn't totally sure
