14 bolt rear end
Discussion in 'The Garage' started by tcoker79, Sep 6, 2006.
  1. tcoker79
    tcoker79 Registered Member
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Will a 14FF from a 79 1 ton van bolt in or will it need the spring perches moved? Is a $150 a good price with 4.10 gears? Thanks guys!
  2. clutchburner72
    clutchburner72 Newbie
    Apr 14, 2003
    lakewood
    ya you'll diffinately have to have them moved in some i'm not sure but i think it's 2" on both sides.
  3. tcoker79
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    wheel surface to wheel surface are the same though, right?
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    van axles are a different width from the truck 14 bolt. I'm pretty sure they are wider. they use different hubs and axle shafts too. truck 14 bolts are a dime a dozen. 4.10's being one of the most common gear ratio's.
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    van 47" perches. = move for sure
    shock mounts = move also
    3" wider than wides truck axle. but same track width as a dana 60 frt.
    van only for shafts if you break one. :haha:
    150 kind of o.k. i hardly find them used in the yards hear.
