14 bolt rear oil leak on disk brakes, rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Flipper, Oct 19, 2000.
  1. Flipper
    Flipper Registered Member
    Oct 19, 2000
    38
    West of Mpls. MN
    Have a 14 bolt rear end with homemade disk brake set-up
    Question is does anybody make a speedy sleeve for the hub seal area. I've put on speedy sleeves on yokes but this is a way different application. Oh ya it's a 78 full floater.Thanks and pray for snow!
  2. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
  3. wstolar
    wstolar Registered Member
    Sep 17, 2000
    46
    Sorry I can't offer you any info on the seal question. However, your post caught my eye when you mentioned the disc brake setup. I am interested in putting discs on my 14 bolt FF. I possible, I would be very interested to hear how you did your setup.
    Thanks - Walter
    wstolar@hotmail.com
  4. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Carquest part # 99282 for the sleeve kit. National carries the same thing w/same number. You'll need to use a piece of 3" exhaust pipe to install the sleeve since the supplied tool is too short.
    Smitty
