14 bolt rear SF vs. FF
Discussion in 'The Garage' started by SmokinLB7, Mar 25, 2007.
  1. SmokinLB7
    SmokinLB7 1/2 ton status
    Mar 21, 2007
    118
    Greeley, CO
    Alright so i have been searching around but cannot find it. What is the dissadvantage to having the Semi Float 14 bolt? Everyone has full float but i can get a really good deal on a SF. But i dont want to buy it if it is going to be horrible. Thanks in advance to anyone who helps a confused kid out. :rolleyes:
    Zach
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    one dissadvantage is it is semi float, if you break and axle shaft (doubtfull you would) the whole tire/drum axle will walk its way out.
    i ran a 14bsf for a long time, the only reason im going to FF is gears are cheaper, and i question the longevity with the new big block
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Lockers are cheaper for a 14bff as well. What are you trying to do with your truck?
    If you want to keep 6 lugs, the 14bsf is an upgrade over a 10 or 12 bolt rear. If it's an 8-lug, pass on it. 14bff are insanely common.
  4. SmokinLB7
    Mar 21, 2007
    118
    Greeley, CO
    Those are good points. Thanks for the advice. I guess that i will wait a bit for another FF to come my way.
    I am going to rock crawler it. I will be running 38.5's with a 6" lift. So i need some meat.
  5. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    thats dana60 front territory brotha.
  6. SmokinLB7
    Mar 21, 2007
    118
    Greeley, CO
    Im gonna do that too brotha
  7. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    sorry for the hijack
    can you convert a 14ff to six lug ?
  8. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    there is no real conversion to six lug but you can use spacer/adapters and somebody was working on or had a kit for it but the end cost was way too much...... try searching the topic, it has been covered here before
  9. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    The adapters are insanely pricey. Cheaper to buy 8 lug outers and new wheels.
