14 Bolt Rebuild questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Jul 20, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Easy question:
    OK, Everyone.....TRustyK5 has belped alot with my questions about changing to a 14 Bolt rear. I just researched an exploded view of a 14 Bolt and it appears be be much simplier than my limited slip 10 bolt. The exploded view does not show any spider gears. The only internal mechanisms appear to be the ring and pinion gears....am I missing anything? Is that what the inside of a full float 14 bolt contains? If so....than all I need to rebuild/replace is the ring and pinion gears so I can change it to 4.10 ratio and the bearings & seals. Is that all there is to it...seems too simple, there has to be more. Any help here would be appreciated. Thanks...
    ....and ....if anyone has pictures of the inside of a 14 bolt I would love to see them!
    Chris
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Don't have any pictures handy, but if it's an open diff, then it has 4 spider gears. If it's a Gov-Loc, then it has 3 spider gears. They are pretty easy to work on. Installing a Detroit Locker in one is a piece of cake. [​IMG]
  3. 1986Blazer
    Jun 13, 2001
    511
    Thanks Harry:
    The exploded view I have just does not show any spider gears (also called side gears according to GM). I am looking at a Full Float 10 1/2 14 Bolt Axle. On the FF, does power go to both wheels at all times? IK am just trying to prep myself for what I have to do.
  4. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    here is an option for you. don't mess with rebuilding the 14 bolt, keep it for parts. Call me up and for $775 plus shipping I will send you a brand spankin new in the crate ff 14 bolt with 4.56 gears. What do you think?
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Actually, there are side gears in addition to the spider gears. [​IMG] The spider gears provide differential action while the side gears actually provide drive to the axle shafts.
