14 bolt ring gear tightening
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ironnut, May 22, 2005.
  1. ironnut
    ironnut Registered Member
    Jul 14, 2004
    77
    Missoula, MT/Redmond, WA
    Putting a detroit in my 14ff and need to torque the ring gear bolts to 120lbs but problem is with the carrier out of the axle I cannot get the bolts torqued without turning the hole thing. I might try it when the carrier is back in the axle housing. SO for now I just set my impact wrench on high and tighteneg them. WHat did you all do to get them torqued? I also tried putting a pry bar to hold the carrier but did not want to damage anything.
  2. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    For small carriers I put them in a vice. For big carriers I put them in the press.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Just do it with it back into the carrier, its alot easier. :)
