14-bolt Semi-Float, 14-bolt Full-Float
Discussion in 'The Garage' started by BozoWise, Apr 15, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    How can you tell the difference between the 14-bolt Semi-Float, 14-bolt Full-Float. Which one is prefered and why? Thanks in advance. I am about to do some swaping for my gm 12 bolt rear
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Try a search.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The Full Floater is prefered. It is cheaper, stronger (alot stronger), cheaper for parts to work on it. A detroit locker is only $350 or less.
    The way to tell them apart is easy. The FF has a big hub sticking out of where the wheel mounts, and the SF hub is just like a normal 10 or 12 bolt hub (flat).
    I picked my FF for $200, 4.56 gears are $200, install kit for gears is $150+/-, gear install is $200, brakes and bearings are around $150+/-, hybrid ujoint is $25, and if you want one, a detroit locker is $350. So for $1200+/- you have a completely rebuilt axle that you couldn't break with a built big block and 44's.
    I am going to have my spider gears welded like the tech article, and save myself the $350 for the detroit.
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Thanks for the info. I felt that the bolted assem. sticking through the center of the wheel was for the FF. Once again thanks for the info.
    My search was leading me no-where on the way to identify them.
