14 bolt semi float?
Discussion in 'The Garage' started by HOSS874X4, Jun 4, 2006.
  1. HOSS874X4
    HOSS874X4 1/2 ton status
    Apr 17, 2005
    118
    DALLAS TEXAS
    do you have to buy or modify anything to fit it in a 91 blazer that used to have a 10 bolt?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Theres a post in here by Dyeger, Dontoe or Divorced about the 14SF. Lot of specs and good info..
    On the newer 88+ trucks you may have to move the spring perches or shock mounts.... Never measured the mounts ont he one I had... And I ithink most had a larger u-joint...
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Most likely have to move the sping mounts on the axle.
    Where in Dallas are you located?
  4. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Dyeager has it. Search for "14sf tech" any 14sf before the 88 one will bolt in.
    Also, I would say that 70%, from what Ive seen, come 8 lug, so you might have to buy new shafts if you want 6 lug.
  5. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    the 14sf from my 86 3/4 ton bolted right up to my 91 blazer (that just happens to be for sale guys!!!)
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
  7. HOSS874X4
    Apr 17, 2005
    118
    DALLAS TEXAS
    im in irving ,how much do you want for that 14 bolt oneofthefew?
  8. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    he means blazer is for sale, not the axle.
  9. HOSS874X4
    Apr 17, 2005
    118
    DALLAS TEXAS
    oh how much?
  10. oneofthefewbmx
    Oct 6, 2004
    579
    Copperas Cove, TX
  11. HOSS874X4
    Apr 17, 2005
    118
    DALLAS TEXAS
    how far is belton from irving? what parts would it take to drive it home?
  12. oneofthefewbmx
    Oct 6, 2004
    579
    Copperas Cove, TX
    i believe irving is up my dallas, if so its about a 3 hour drive....but it would need quite a bit of work to drive it home....mostly a tranny and t-case....also i think one of our fellow members is pretty set on buying it...sorry
  13. wolfman
    wolfman Registered Member
    Jul 10, 2006
    37
    Texas
