14 bolt semi float
Discussion in 'The Garage' started by chvymudin3388, Oct 22, 2006.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    ok i found 94 semi float 14 bolt 6 lug on ebay. what will i have to do to make it ft what u joint? are the e-brakes gonna hook up and how wide are they? is it not gonna look right? and is the snout shorter on it than my stock 10 bolt ? will i need to lengthen my drive shaft?
  2. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    If you can find an October Petersons, they installed one in a Tahoe or Suburban. The U-Joint you need is a Precision 447. The center section is less than an inch longer so your driveshaft is fine. They say you can use the same brake cables since it is only ~an inch wider than the stock 10 bolt.
    I will be installing one next weekend that I bought from a local yard for $100.
