14 Bolt Semi Floater install, haven't seen a guide on it.
Discussion in 'The Garage' started by sled_dog, Aug 12, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    14 Bolt Semi Floater install, haven\'t seen a guide on it.
    Do I use the same UJoint as a FF and it is a 2wd rear so will I have to move shock moutns?
  2. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Re: 14 Bolt Semi Floater install, haven\'t seen a guide on it.
    I got my 14bsf from an 82 2WD diesel and didn't have to move spring perches. I did however move the driver (IIRC)side shock mount becuase it hung down way too low. I just moved it up as high as the passenger side one. I don't know about the u-joint. The yoke that was on the axle was bad so I killed two birds with one stone and replaced the bad yoke with a 1350 series and got the pinion seal replaced.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I think I will replace both shock mounts, put them up higher for better ground clearance.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I took a 14SF out of my 84 Burb and installed a 14FF. I re-used the joint - it was the same size (1350 series). /forums/images/graemlins/thumb.gif
  5. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I recently installed an '84 2wd 14bsf in my '87 K5. The spring mounts are correct, the shock mounts are correct location but hang down about 1 1/4 inches too low. I just sectioned an inch out of the mounts and welded them back in. I'll try to get some pic's some day. Got a new camera and it's waaaaay smarter than me right now.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Back in the day I upgraded from my grenaded 12 bolt to a sf14. It bolted right up with nothing but a bastard joint necessary to make it work. I went through it and a D70 before I arrived at my current 14FF. I am very happy with it and would not waste my time on anything other that a portal axle or FF14.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm going to a 14ff, simply cause I think 3.42s aren't gonna be enough gear. Going 4.10 and 35s.
