14 bolt semi floater u joint size?
Discussion in 'The Garage' started by sled_dog, Mar 5, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    anyone know what size u-joint would be in my 1997 C2500 pickup with a semi float 14 bolt? I want to swap out the rear for a Dana 60 and am puting a list of everything I would need to do together.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    should be a 1350
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hopefully. hopefully the driveshaft works out fine. Not sure but hoping the dana 60 has 4.10s in it. it will be nice to have a dana 60 under it, give me a good base in the rear for doing the SFA later.
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    my 6 lug 14sf i had was 1350
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    definetly 1350
  7. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    you know there really isnt a strength difference right? only a .25 inch in ring gear diameter.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    plus full float axle shafts, plus the aftermarket support of the dana 60 vs the 14 bolt semi floater, plus the possibility it is already 4.10 gears vs the 3.73s I have now. ;) strength isn't the real concern, the ability to build it up into something stronger down the road is.
