14 bolt SF 6 lug
Discussion in 'Suspension | Axle' started by Liberator, Feb 11, 2005.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    14 bolt semi-floater 6 lug from a 1988 p/u, same track width as stock 10 bolt, 3.73 gears, New spring perches and shock mounts already welded, ready to bolt into blazer, w/e-brake cables.
    Make an offer!
    Will ship freight to " Hold at dock" for pickup, you pay shipping. I can get discounted shipping rates! Please don't ask for shipping rates unless you are serious about buying.
  2. mrpoorboy
    mrpoorboy Registered Member
    Feb 21, 2005
    84
    hillsboro, oregon
    you still have this axle available?
  3. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    ya caught my attention, but i haven't shopped around enough to make offer, gimme a ballpark..
  4. Liberator
    Jul 16, 2001
    276
    I'm asking $500 OR best offer. I paid $600 from the wrecking yard. I promptly began work relocating the spring perches and shock mounts for the blazer. The axle was in a new truck when it was wrecked. I put about 5,000 miles on it before I put the truck into storage. This is a 6-lug that will work with stock rims. All I need for shipping quotes is a zip. Just tell me what you think it's worth to you. Keep in mind the axle is fairly new and will bolt directly into the blazer (need a conversion u-joint 1310/1350) when you price search.
  5. k5james
    k5james 1/2 ton status
    Feb 25, 2004
    792
    San Diego, CA
    I'm definitely interested. Some unexpected costs have seriously reduced my Ford 9" allownce so I'm weighing some other options. Will it fit 15x8 rims and would there be an issue swapping it on a 72 Blazer other than moving the perches? Also, where are you in SoCal? Let me know.
  6. Liberator
    Jul 16, 2001
    276
    It will fit 15x8 rims but I'm not sure what will be required to get it under a '72. I'm in Tustin near the I-5 and 55 Fwy interchange, about 1 1/2 hrs from SD. I'll be taking it to the offroad swapmeet in Rialto on the 20th.
  7. Liberator
    Jul 16, 2001
    276
    Ready to ship
    Ok, I pulled the axle from the truck and it's ready to ship! I can't believe no one wants this thing! It's a direct bolt in with new u-bolts, a conversion u-joint and it's 6 LUG! Bolt-in 6 lug beef! Those of you that want some serious beef in the rear end without going through the whole 8-lug fiasco should consider this axle. Just make a reasonable offer. The axle has low miles, is lighter than a FF, has a 6-lug bolt pattern, works with stock rims, drum brakes work great with the stock proportioning system, 9.5" ring gear, better ground clearance than a full-floater, and is very strong! If you aren't planning on touching the clouds with lift height, hacking the hell out of your body to run tires taller than you and never plan on running them, you don't need a FF. The SF 14 bolt is a 3/4 ton axle and plenty strong for wheeling! Did I mention it's 6-lug so it'll work with stock rims?
  8. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    i need it but it needs to fit a 98 z71 so you would need to move the perches again:mad: does it have the locker?
  9. Liberator
    Jul 16, 2001
    276
    No locker. I have a buddy that did just that in his '96 Z-71. He used the truck to tow his boat until the 10 bolt blew apart. He doesn't worry anymore with the SF in his truck. I talked him out of a FF because he had some nice rims that were 6-lug. The axle dropped right into his truck, unlike mine. He even gained a wider track width by using a 2wd axle. The one I have for sale is a 4wd so it's the same track width as my 87 Blazer. If you can find a 6-lug SF I'd say go for it! I'll take a 6-lug Semi-floater 14 over a 10 bolt anyday!
  10. mrpoorboy
    Feb 21, 2005
    84
    hillsboro, oregon
    hmmmmm
    the wheels are turnin
  11. johnnyclueless
    johnnyclueless Registered Member
    Nov 26, 2004
    51
    Have you sold it yet - I might be interested - I have a pretty week 12 bolt with weak gears in my 78 - I'm at 85250
  12. Liberator
    Jul 16, 2001
    276
    TT for pic
  13. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    I really need that rearend but I can't afford $500. My 12 bolt is about to go out.
  14. dmanblazer
    Sep 5, 2004
    165
    Wellington, Kansas
    Let's see if we can make some kind of deal? ttt
