14 bolt SF 8-lug to 6-lug convert??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Jimmy, Apr 20, 2001.
  1. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Just wondering if anyone knows whats involved in this swap...Got a line on a cheap 86 3/4t Suburban 14 bolt SF rear with 8-lugs. I know the axles and drums can be redrilled but would like to avoid this and be able to use off the shelf replacment parts. Is the only difference the axles and drums or are all the internal brake bits different requiring all new parts from the backing plate out??? Whats the width of this axle compared to a 12 bolt? Basically looking for as much info and insight on this from the vast resourses here on CK5.
    Thanks guys,
    James
    79jimmy@home.com
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I've heard of people putting in 88+ 6 lug shafts, but I've also heard those housings are wider, so how does that work? Off-the-shelf 6 lug drums should work, but the shafts will probably have to be machined or custom made.</font color=blue>
  3. 79Jimmy
    May 10, 2000
    214
    Richmond BC, Canada
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, I did some checking on this. ORU says: get the shafts, drums, backing plates all from a 6 lug SF from 88 and newer. They will bolt right in. Very simple. The housing lengths are the same. This makes for some very simple rebuilding and swapping since the parts interchange and the spring perches are in the correct location, especially when using the 87 and older SF rears. If disc brakes are wanted, get the stuff from TSM for the 88 and newer years.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I thought you dont need the backing plates?
    90K5
  6. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    the latest petersons 4-wheel drive and off road as a tech article on this if it where me id look fora 3/4 light duty chevy 88 and newer becosue thats what the are a 14 sf 6 lug
    AJ
    (Your right i dont understand the jeep thing)
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    NAtional Drivetrain has the axle shafts forabout $89 ea.. 6luggers.... They have an overall measurement of them, give them a call, they will tell you the measurement and then you can measure the 8 lug shafts...
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
  8. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    Re: 14 bolt SF 8-lug to 6-lug convert?? *DELETED*
    Post deleted by 1990k5
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The 88 and newer trucks axles wont bolt up. Theg spring pads and shock mounts are different. The best way to do this swap is to get an 8 lugger from a 81-87 3/4 ton and swap out the axleshafts and drums.
    90K5
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The SF and FF 14-bolts are completely different. On the FF versions, the axleshafts have nothing to do with the wheel lug pattern and it would require quite a bit of work to convert it to 6-lug. I believe ORU offers a FF 14-bolt with a 6-lug pattern......but in order to get the 6-lug pattern it was converted to a SF design and they are pretty pricey ($2,000+).
    On the other hand, you can convert an SF 14-bolt over to 6-lug by simply redrilling the axle shafts and drums, or swapping over to 6-lug parts (assuming the axleshaft length is the same).
