14 Bolt SF (did search just clarifying)
Discussion in 'The Garage' started by MTBLAZER89, Feb 11, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok I found three 14 Bolt SF rearends today under later model chevy's 1/2 tons 6 lug (88-up). These are a direct bolt in correct spring perches shocks etc.. I just need a conversion U-joint I think this is what I have gathered just clarifying. Thanks
    -Brian /forums/images/graemlins/k5.gif
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i think the perches and mounts are actually different
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK anymore opinions moving this back to top was going to pick up one of these this week. Thanks everyone
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    If I understand you correctly make sure the WMS to WMS is the same as there is some variations, and you will also have to move the perches and shock mounts and get a conversion U joint from Napa.
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I believe that you will have to move spring perches, but other than that it should work. This axle is supposedly equal in strenght to a semi-float D60. /forums/images/graemlins/laugh.gif
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    The 88-up axles are the correct width. They, however, do not have the correct spring perch width. You will have to move the perches. I would get the axle complete with the brakes and just move the perches. You will also probably need a conversion U-joint too.
    If you can get it with brakes and all, you will be much further ahead. Moving spring perches is easy for a good welder to do.
    John
