14 bolt SF/FF questions
Discussion in 'The Garage' started by KevinsK5, Jan 3, 2006.
  1. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    What year did GM replace the 14FF with the 14SF in 3/4 ton single wheel trucks and suburbans? What is most common u-joint size on a 14FF, 1350? Thanks, Kevin
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I believe it was somewhere in the 78-81 era when the SF's started showing up in the 3/4 tons. Nothing is exact with GM though. They had a lot of overlap in all of their changes in those years. Yeah 1350 is the 14BFF joint
  3. AV8
    AV8 Registered Member
    Oct 8, 2005
    45
    Winston Salem, NC
    I believe the change occured between 82-83.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    81 was the first year of the 14bsf. the diesel and bigblock 2wd 3/4 tons got a 14bff, all the other 3/4 tons got a sf
  5. 2500SWATBurb
    2500SWATBurb Registered Member
    Dec 18, 2005
    30
    North Carolina
    1984 was first year for SF in 3/4 Tons..
  6. AV8
    Oct 8, 2005
    45
    Winston Salem, NC
    Well, my 83 Suburban has a 14sf. I think they mixed them up a little back then, I've seen some with FF and some with SF.
  7. 2500SWATBurb
    Dec 18, 2005
    30
    North Carolina
    For Suburbans anyway. Not sure about any other applications.
  8. 2500SWATBurb
    Dec 18, 2005
    30
    North Carolina
    What kind of truck is your 83?
  9. AV8
    Oct 8, 2005
    45
    Winston Salem, NC
    It is a Suburban.
  10. 2500SWATBurb
    Dec 18, 2005
    30
    North Carolina
    Shows how much I know! :doah:
    What part of NC are you from?
  11. AV8
    Oct 8, 2005
    45
    Winston Salem, NC
    I'm in Winston Salem....you?
  12. 2500SWATBurb
    Dec 18, 2005
    30
    North Carolina
    Near Asheville
  13. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I agree with '81, and bigblock... but my '84 C20 Burb w/diesel had a 14SF stock.
  14. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i though the 2wd diesels got the ff, but i could be wrong on that part. i know the BBC got the ff
  15. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Subs never came with a 14bff only one ton trucks did. 1/2 tons had 10 bolts, maybe 12bolts at some point in production others will know better. 3/4 ton had 14bsf.
    Right?
  16. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    all I know is that in 3/4 tons they switched them back and forth, some had the SF and some had the FF. just look and then you will be 100% sure.
  17. dyeager535
    26,982
    191
    I'm sure it was based on the GVW, just like '88+ 3/4 ton pick ups.
  18. u2slow
    May 9, 2001
    2,217
    BC Canada
    Nope. Assuming 81-91 context... 3/4-ton Subs used the 14bFF with the 454, otherwise the 14bsf.
    Here's the '81 pickup spec sheet:
    http://brochures.slosh.com/1981/pickups20.jpg
  19. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Ditto, a neighbor has a 94 with a FF, big block
