14 bolt SF to 14 bolt FF swap?
Discussion in 'The Garage' started by sled_dog, Oct 19, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    U joint swap right over or not? My 89 3/4 ton burb is gonna get a 14 bolt FF in place of its present SF.
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Mine were a little big. I used a 1ton rear shaft and standard U joint but had to grind a little on the cap edge to fit with in the ears of the SF. No vibes and cheaper than a conversion joint.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you said fit in the ears of the SF? I am replacing a SF with a FF...
  4. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Opps. Sorry I'm /forums/images/graemlins/screwy.gif I've got my FF on the stand rebuilding it. So I put a SF in while that was going on. The ujoints may be a tad small then.
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I think the the 14sf uses an 1350 u-joint.
    what's the difference between an 3/4 and 1 ton 14FF, besides the shock mounts an spring perches?
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    CAN be brake differences. 2 different size drums on 14 bolts.
