14 Bolt SF Universal---10 Bolt DriveShaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Dec 30, 2003.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    Well I bought the universal #447 percision ujoint. Couple of questions.
    1)My drive shaft has the outside snap ring not the inside C-clip type. The U-Joint 447 has the Inside C-clip type. Why?
    2)On the 14 Bolt SF is it supposed to have any type of snap ring for it or does it just bolt on the yoke???
  2. Monster
    Jun 14, 2002
    68
    UDATEING MY QUESTION
    Just took off The U-Joint off my Drive shaft.
    The width from cap to cap is 3" 3/16
    and the cap diameter 1" 1/16.
    The U-Joint 447 from cap to cap is 3" 5/8
    cap diameter 1" 3/16
    Do I have a stock drive shaft? May be the person who owned it before me changed it???
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the u-joint you need depends not only on your old rear end, but on your transmission as well.. try a precision 348.. thats what i used to go from my 10 bolt 465 to 12 bolt..
  4. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    if no one replies with the correct part # take both measurements that you just gave and most part stores will be able to get you the correct conversion U-Joint.
  5. Monster
    Jun 14, 2002
    68
    Thanks for the info I'll look into that other part number.
    Also I will bring the measurements to the autoparts store.
    <font color="blue"> 86K5,4"suspension,2"body,35bfg,Hotted 700-R4,300Hp,audio Bahn 18"Subwoofer,1200amp,and a broken 10bolt, followed by a EMPTY Wallet. </font> /forums/images/graemlins/k5.gif
  6. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    447 should be the right one. There are two different sizes on the u-joint. The smaller one goes on the shaft and the larger one goes on the axle yoke. The measurements you gave for the 447 joint are the larger side, this side has no retainer clips. The smaller side has the internal retaining clips. These should be about 2 5/8 in appart. If you just took off the original u-joint there shouldn't have been any retaining clips, there should have been the plastic crap there. Measure the smaller size of the u-joint and then measure the shaft yoke. It should fit.
