14 bolt sf width
Discussion in 'The Garage' started by Janitorjim8, Feb 15, 2006.
  1. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    Ok its a 6 lug out of a 2wd, and as i measured from inside of brake drum to brake drum it was around 54 inches, while i measured my 10 bolt and it was around 56- is this because the drums were bigger on this axle, or is it really narrower? will it work under my blazer after i reweld the perches or should i pass?
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    If its a 2wd then it came out of a 99+ truck right? If so, thats where the difference is. My six lug out of 98- is just as wide as the front axle.
  3. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    its out of a pre-98 2wd, so i take it that i measured wrong, or the brake drums come in farther on this one.
  4. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    If its pre 98 then it would be six lug. If its out of a 2wd, it will be 5 lug. As far as I know, chevys were NEVER 5 lug and 4wd. Measure again, width should be 68 inches or so.
  5. Janitorjim8
    Feb 21, 2005
    215
    Illinois
    it is 6 lug- where did you measure from- studs to studs? it is out of a 2wd 1500HD i beleive
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
