14 Bolt SF
Discussion in 'The Garage' started by 2500SWATBurb, Jan 1, 2006.
  1. 2500SWATBurb
    2500SWATBurb Registered Member
    Dec 18, 2005
    30
    North Carolina
    I dont have much luck searching anymore. So I have a quick question.
    Does the 14 Bolt SF 8 lug have a Gov Lock? Does it have any sort of locking device? Just how strong is it? Is it comparable to the Dana60? Any good web sites on the SF 14Bolt?
    Yes I know I wish I had a FF... But I dont.. And wont for a long long time.
    Thanks guys
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    the 14SF is comparable to a D60 rear and it could have a gov-loc, look in your glove box on the option code sticker and if it says G80 you have some sort of posi in there (there were two that GM used) also if you need to know what gears are in it GT4=3.73, GT5=4.10 as far as websites I can't think of one
    http://coloradok5.com/forums/showthread.php?t=160270 this may help a little, you say you won't have a 14FF for a long time but it shouldn't be high on your priority list, your already 8 lug so you don't have to deal with the front end conversion, buying new rims, and swapping u-joints on the rear drive shaft so rolling a 14FF under your truck is just a matter of getting one, but like I said I wouldn't be too worried about it. When you do decide to swap I'm willing to bet somebody would swap you straight up for the 14SF as they are harder to find.
  3. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Depending on the size of tire you plan on runing you might stick with the 14bsf. The 14bff is over 200# heavyer and even shaved has less clearence than a 14bsf. I have been running a 14bsf under my 5700# k5 with 37'' boggers and beating it for 2 years, zero problems so far but I do have a stock motor.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    When you do break your semi floater and watch your tire pass you by..that extra 200 pounds wont matter too much anymore. I like my 14 bolt full floater just for the comfort of knowing if I break an axle, my tire wont go flyin off, they are soooooo cheap and bomb proof and detroit is only like $350..........just my 2 cents.
  5. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've got a sf14 here with a govlock. It done fine for me and I had no problems.
  6. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    I have owned a gov lock in both a sf and a ff 14blt and blew both to smithereens
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you just gotta do what i did... find a 14bff ready to bolt in, completely rebuilt, with a detroit and ss brakeline for 125 bucks:D
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i run a 14bsf, i ran one with a gov loc and never blew it up. swapped in the 4.10s and i actually missed the gov loc. then i welded it. its a strong axle with great clearance. ill run it unless i swap 1 tons in.
