14 Bolt SF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Dec 24, 2003.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    My 10 Bolt with 4.56 gears has broken 4 times on me. I dont off road so I thought it would be ok with 4.56 gears guess not? Now I have a 10 bolt thats no good that I put 0ver 2000 bucks into it.
    So I bought 14bolt SF and front 10bolt 8 Lug 4.10 gears for 500 dollars. It came from a 85 K20.
    I have a 86 K5----> 4"suspension,2"BodyLift,35Bfg,700-R4,StageoneShiftKit,300hp.
    My question is Will these bolt on and can I use the stock driveshaft or will I need a different one.????
    /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    the front you shouldn't have a problem with, you can even use your old calipers. the rear will pretty much be a straight bolt in also. you will need a conversion u-joint to go for the 10 bolt driveshaft yoke to the 14 bsf. the part # should be #447. This should be a NAPA part number. I'm not sure about your e-brake cables. they might be different. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Rick
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    It will bolt in just fine. You will need the U-bolts and spring plates from the K20 for the rear axle. The Napa 447 or Neapco 2-1153 will be needed to convert your rear driveline. the p-brake cables that you have now will bolt up fine.
    The front will will be a bolt-in.
    Hope it helps,
    John
  4. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    You could also buy a set of 6 lug axle shafts and drums for the 14 bolt SF and run the same wheels you have now. If you have a local machine shop you can see if they can redrill your current shafts then all you would have to do is swap on the 6 lug drums.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You could also buy a set of 6 lug axle shafts and drums for the 14 bolt FF and run the same wheels you have now
    Is this what you meant? /forums/images/graemlins/thumb.gif
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    No....
  7. Monster
    Jun 14, 2002
    68
    Thanks for the info guys.
    Did not think about changing the axls to 6 lug. Even if I did that my rims would be to small for the drums.
    Time for NEW rims and tires.!!! /forums/images/graemlins/laugh.gif /forums/images/graemlins/k5.gif
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    No they wouldn't.
  9. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    No....
    Oh, I thought 14bsf's were 6 lug...my bad /forums/images/graemlins/ignore.gif /forums/images/graemlins/rotfl.gif
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    No....
    They came in both 6 and 8 lug versions... obviously the 6 lug version being more desirable.
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    6 lug ones started around '88 or '90 or somewhere in there,
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    88'
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    88'
    good deal /forums/images/graemlins/laugh.gif same year as the axle shafts on at least 10 bolts increased to 30 spline i believe, or was it 31 ?
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I believe they are 33 spline.
  15. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    10 bolts went from 28 to 30 starting in 88 in sparse numbers and all 89's should have them.
    14 SF have always been 33 spline
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    and i take it that FF stayed the same always too even after 87/88, what about 60s fronts and rears ? i know 60 rear changed splines a few times, and for different makes too
  17. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    FF 14 bolt has always been 30 spline.
    Dana 60's have many different spline counts and shaft thicknesses, some require crush sleeves on the pinion and some don't. D60's are a mixed bag, make to sure to use the Material number off of it to get parts.
