14 bolt specs needed fast
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris Demartini, Mar 3, 2002.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>I'm at the shop putting my Detroit locker in, what's the torque spec for the ring gear and bearing cap bolts? I think the bearing caps are 135 ft/lbs but I just want to double check. TIA
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    bearing caps--135
    ring gear--120
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Thanks! /forums/images/icons/smile.gif
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    thanks,
    dam glad i found this/forums/images/icons/smile.gif
    ARQ.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    According to drivetrain warehouse the side caps torque to 100 lbs. and the ring gear torques to 110 lbs. and the pinion support bolts to 70 lbs.
  6. SCOOBYDANNN
    Sep 4, 2001
    2,131
    27
    El Paso, TEXAS
    I got the specs from the service manual that i got w/ my truck, im sure either is fine.
