14 Bolt Spindle Assembly
Discussion in 'The Garage' started by willyswanter, Apr 23, 2004.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ok, on the 89 and later 14 bolts that use the single spindle nut, key, and snap ring, is there supposed to be a washer behind the nut like the older 2 nut systems used or no? The diagrams I am looking at had no washer there and the dealerships are saying they do not have a part # for one. But when I pulled my axle apart there was one in there on each side and I put them back on when I rebuilt it. Is this a fluke or is it really supposed to be there? Could this be what caused my bearing to die on the highway?
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Not the same axle I know, but neither of my Dana 70 rears (which have the same wheel bearing adjustment nuts and such) have any sort of washer behind the adjusting nut. They both use the key and snapring method. How did you adjust them? I always do 50 ft lbs then back off one slot and ive never had a problem.
  3. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yep, thats what the manual says to do and thats what I did. The pass. side is fine, just happened to the drivers side and the bearings are maybe 2 months old...
