14 bolt spool- pic's
Discussion in 'The Garage' started by odoa3, Aug 1, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I posted up a thread a couple weeks ago with questions about installing a 14 bolt spool. As I haven't seen any pictures of one one here thought I would post a couple pic's of it. It is a heavy beast. Don't think I will break it anytime soon.
    One of it installed
  2. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    Is this a Yukon? and what did you pay for it?
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I doubt you'll ever break it, even if you try.. now the gears are another story. :wink1: Thanks for the pics.. looks good.
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Yes, it is a Yukon, got it from Randy's- I think it was $279 with shipping to Alaska.
    txfireman- I almost hope the gears break..... I need a reason to buy some 5:13. :D 's
  5. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    time for disk brakes :D Do you have to reset gear backlash or reset anything when you install the spool?
  6. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Disk brakes are next year. We had to play with the depth of the ring and pinion mesh a little bit. But all in all, it was not too bad.
  7. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    mmmm beefy looks awesome. i wish they wasnt such a pain on the street i like to drive my toys to the places i wheel
    balzer
  8. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    you wont break that monster! it you run deeper then 4:10's you ofcourse have to run the thick gear which i assume is, or should be stronger than a regular gear, atleast the cross section. the teeth strength should be the same. so my question is what would be the next weak link?. i would guess the axles, which can be improved with aftermarket axles. so if you basicly have a bomb proof 14ff the only draw backs is or should be tire wear, and maybe in snow or wet street driving, right? if you dont do much snow and limit your street driving or have a different DD, you would have a killer affordable setup. i think im interested in one possibily. feed back please, thanks.
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Wow. Thats different looking than the ones I have been seeing on the net. The difference is the others are machanied around the ring gear bolts...
    Cool beans though! :thumb:
    BTW, did you happen to weigh the spool and the stock carrier with spiders? Just wondering what the weight difference was.....
  10. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    wow that thing is beef :D
    I've been running an mini spool in my 14ff for about 4 weeks now and barely notice back there. my turning radius sucks now but it wasn't that good to begin with anyways and around corners I just go alittle slower. The tires seem to be doing good so far.
  11. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Emmettology 101 - I didn't weigh the spool or the old carrier. I will check the shipping box and see if the weight of the spool is on there. I sold the old carrier so I will be mailing that out - I will get the weight of that. They seem to be pretty close in weight- I think the spool weighs just a little more though.
    rdn2blazer- The only road this thing sees is on the way to the trail. Maybe 20 or 30 miles.... so I figured it wouldn't be such a big deal. When the Boggers start melting away my story may change. :rolleyes:
  12. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Who is working on that thing ? Dorf ?
  13. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Who is dorf?
