14 bolt spool
Discussion in 'The Garage' started by Deadman514, Jul 22, 2003.
  1. Deadman514
    Deadman514 Registered Member
    Aug 28, 2002
    23
    No -I don't have a GM truck anymore. I do have a GM 14 bolt rear axle on my 78 Bronco. I hate lockers and limited slip diffs are useless...I don't want to weld the spiders...I'm looking for a spool (or mini spool). The only one I've found is for 46spline axles (which I don't have the cash for right now). I did a search already -DTW says they won't be making them for a couple years at least. Help!
    Thanks in advance
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Detroit or welded is the only ways to go on a 14 bolt. No one makes a spool yet. I have a detoit and can't even tell it is there on the street.
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    sorry to be the one who gives you the bad news...assuming its the full-floater, that one for the custom shafts is the only one I've seen on the market. Maybe someone else will have had better luck.
  4. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is wrong with a detroit locker?
  5. Deadman514
    Aug 28, 2002
    23
    I've only had one when I had a 9" Ford axle -but from the stories I hear -there's not much difference. Off road -no problems. But this is my only truck now -and my daily driver -so it's gotta be able to work on the street too.
    When it was new -it was almost always locked. It was fine then -only unlocked on a corner on pavement. Once it broke in (couple months) it would lock and unlock when I got on and off the gas. When it would lock and unlock -it would throw me into the next lane. Pretty scary on the Harlem River Drive in NYC- especially when you're up 30 feet off the water -at 60mph with a guard rail that's less than half as tall as my tires!! /forums/images/graemlins/k5.gif
