14 bolt spring plate?
Discussion in 'The Garage' started by cegusman, Aug 6, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What are the dimension of the bolt holes on a spring plates for a 14 bolt ff?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Well... the springs are 2.5" wide, and the axle tube is 3-3/8" in diameter. That means the plates have to measure those two distances between the inside edges of the four bolt holes.
    I had some Ford plates I was going to use... They were for a 3.5" tube (I called that close enough /forums/images/graemlins/wink.gif ) but they were for 3" wide springs. (not close enough IMO). Luckily I could reuse the 14SF plates with the 14FF. /forums/images/graemlins/grin.gif
