14 bolt SRW vs. DRW
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Nov 21, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    70's 14 bolt FF 10.5"
    anyone happen to know WMS to WMS distance diference from DRW to SRW ? which is wider and which is narrower and did any 1 tons have narrower spring pack to spring pack distance difference from 42.5" 34 ton?
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    found spring perch info in a reply by Rene in August
    i just need to know WMS to WMS measurement differences from 3/4 ton 65 1/2" to whatever 1 ton dually are
    thanks
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    maybe im jujst asking in wrong way hmm..
    just need to know the overall width from WMS to other WMS on a regular old dually 1 ton pickup chassis 14 bolt FF,
    the ultimate would be to have measurements from outer wheel outer sidewall over to opposite outer wheel outer side wall- along with inners also- and also to know what size tires that are on the axle that someone takes these measurements from.
    and, if anyone needs measurements off a 60's SRW FF Dana 60 or 70's 14-bolt same description or 80's dually van chassis 14-bolt FF then i can get em.
    thanks for anything at all
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Here's the info that I have -
    GM Dana 60 front (single wheel) ...................69"
    GM Dana 60 front (dual rear wheel) ..............77" ; +4" on each side vs single wheel
    GM 14 Bolt rear FF (pickups, DRW or SRW) ....................67"
    GM 14 Bolt rear FF (dual wheel cab &amp; chassis)........................63"
    GM 14 Bolt rear SemiF (single wheel) ..............66"
    GM Dana 44 Front (single wheel) ..............69"8-lug; 67" 6-lug
    GM 10 bolt front (single wheel) ..............69" 8"lug; 67" 6-lug
    GM 14 Bolt rear (Van single wheel) ...............70"
    GM 12 bolt and 10 bolt rear .....................64"
    I am under the impression that the 14 bolt dually axles found under pickups are the same width regardless of whether they are single or dual wheel.
    </font color>
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The DRW *pickup* is approx 77"... but thats for the 88-up body style. Same (similar?) width to a 14-bolt from a cube- van or step-van. (Replaced the Dana 70 DRW around 92-93 or so.)
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    same width ? cereal ? nice nice, hope so /forums/images/graemlins/laugh.gif this should turn out pretty cool then, maybe have to modify fleet bed tubs a little, possibly, dont have to on 67-72 though, so hmm,.,,
    thanks, i appreicate it!
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    So the late model DRW P/U rears are as wide as the old style DRW D60 fronts (I'm only refering to WMS-WMS)? Very cool info. Off to the junkyard I go.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    any chance anyone has access to a dually pickup chassis 14 bolt FF with the duallies on it to get measurement from inside sidewall of inner tire to the same thing on other end of axle ?
    thanks
  9. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    My friend has it so monday morning I will give you those measurments.
