14 bolt SRW .vs DRW
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seattlek5, Sep 4, 2003.
  1. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    What is the difference between the single and dual 14bolts? I'm thinking the crewcab needs to be a dually /forums/images/graemlins/thumb.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    For one they are diferent widths and two the spring perches are narrower on 1 tons and duallies are only 1 tons. Find a 3/4 ton 14 bolt, they are just as or more common than the 1 ton version because the 3/4 version bolts right in on half tons.
    85K5 3/4 ton,14boltFF,10bolt, 9"lift,35"boggers,16.5x14 welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Pretty sure this is for his 1 ton truck, so I would guess that a 1 ton dually rearend would bolt in /forums/images/graemlins/thinking.gif
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    For a 14 bolt, the housings are supposed to be the same but the bearing hubs are different. The wheel mounting flange is positioned differently between the two versions, the flange is out further on a dually. Dr. Watson addressed this recently in a thread about using Hummer wheels.
    FYI - second gen dually pick ups used D70HD's not 14 bolts so be sure to check the overall wms for you application.
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] You have a SRW Crew cab longbed? 4x4? Those things are awesome in my opinion, as long as its a 4x4 of course. I love the extra lights on the 1ton, across the roof and tailgate. /forums/images/graemlins/crewcab.gif There is one around here that is an 89-91 12"lift, 39.5boggers, 16.5x14 welds. THey are kind of rare, don't convert to dually, please! /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif
  6. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    The 14 Bolt FF dually axle came on cab and chasis 1 ton dual wheel trucks, not dually pick ups. The Dana 70HD is the wide dually axle you see on dual wheel pick ups. They are different in widths. Both will bolt in just fine to any 1 ton truck - cab and chasis, dually or SRW 1 ton pick up truck. But, the inner dual tire on 14 bolt FF dually axle will not clear the inner fenders of the dually or SRW pick up beds. The outter tire will not tuck under the fenders on the SRW bed and will be tucked too far in on the dually bed. You want a Dana 70HD and the dually bed for it all to fit correctly.
    As for the difference between the 14 BoltFF single and dual axles, the housings are the same except the mounting bracket for the backing plates are welded in different locations on the housings, the hubs are different and the drums are different.
    Eric M.
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    OK, so the infamous "van 14FF" is just wider hub spacing, not a wider housing?
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I think the axle tubes are a few inches wider.
