14 Bolt Swap Question-shock mounts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tommy, Jul 5, 2000.
  1. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    I got the perches and spring mounts cut off, ready to reweld in right spot, noticed the shock mount will be half on the pumpkin and half off if I spaced it like the facory did on the 12 bolt. What did you guys do as for mounts, just move them out a little?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    what 14 bolt did you use? all mine just swapped in. no pearches or shock mounts to modify. just bolt in.
    your right. I don't understand the jeep thing!
  3. Tommy
    Feb 21, 2000
    260
    Alabama
    14 Bolt FF out of a 74 suburban, even had to move spring perches in about 3" total.
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    You should of kept looking, cause I didnt have to modify anything. I bolted my 14 boltFF right in place of the 12 I took out. Actually the only thing I had to modify is the E brake cable attachments. Otherwise, it was a bolt in job.
  5. Tommy
    Feb 21, 2000
    260
    Alabama
    Well its not the end of the world to have to move this and reweld, but I guess to some its more work than they want to tackle. I just had nothing in the axles, and everything to remove and reweld, so looking for another one was not an option. thanks for your help.
