14 bolt swap
Discussion in 'The Garage' started by SUB-ZERO, Nov 14, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I remember seeing a post on here that gave a step-by-step swap from a 10bolt rear to a 14bff.However,now I can't find it.Does anybody have a link?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  3. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Thats it!Thanks.Where can I get u-bolts and spring plates for the 14bff?And what is the part # for the adaptor for the 1350 to 1310 piece for the driveshaft?
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Get spring plates at a wrecking yard. They are the same as the ones for a 14bSF.
    Most spring shops can bend up u-bolts any size you want. If you're a cheap bastard like me you can use some from a mid/late 90's E250/350. [​IMG]
  5. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    are you sure you need a 1310 to 1350 ujoint?
    this was what i was told and wasn't correct for my 89
    i needed a s44 to 1350 which is neapco part# 2-1153
    there is also the 1330 to 1350 which is neapco part# 2-3050
    and the 1310 to 1350 is neapco part # 3-3140
  6. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Thanks for the part #'s I'll check which one I need before I buy.None of the yards have 14 bolt axles around here.Can you buy the plates new?
  7. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    you may be able to get them from a dealer, i know they can be bought online i don't remember the site tho
  8. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Thanks guys.I found some at ORD with the u-bolt for $68.00!
  9. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    DIY makes spring plates, so does greatlakesoffroad. Both vendors here...
    j
