14 bolt swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bhintz, Apr 23, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    Im sure this has been ask before but, when swiching in a 14 bolt for a 10 bolt I know you have to change the u-joint, but is there anything else I will need and is the u-joint size 1350? /forums/images/graemlins/confused.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Search feature. If you are switching from 10-->14 and you don't switch your driveshaft ujoint from the 1/2 style you need the Napa #447 ujoint. It is half 1310 (1/2 ton) half 1350 (3/4 & 1 ton). If you do switch the rear driveshaft ujoint then the joint you will want is the 1350. That should be what your 14bff is set up for. Mine was, and most are.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    you'll need ff14-sized u-bolts and spring plates too....
    j
  4. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Before you hammer out the old joint make sure it is different on the yoke. The yoke on the 14bolt was the same size as the yoke on my 10 bolt. I believe the NAPA 447 is for the front drive shaft. I have not gotten that far, so I am not 100% sure.
  5. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    I'd be awfully suprised if the yoke on that ff14b is the same as the yoke on the 10b.
    Also, I can't help ya on the u-joint. I got mine from a local driveline shop. I don't even recall the mfg of it. Spose I could go dig out the receipt to find out, if need be. However, I do recall ordering a NAPA ujoint and it wasn't what I needed so I had to send it back. I've probably got a reciept of that transaction as well. My point is, make sure you're getting the right ujoint if you're getting it from NAPA.
    As for the spring plates - you can get by just slightly drilling out the 1/2ton plates to fit the 3/4ton ubolts, if you want.
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Hossbaby50 is correct. You will need hybrid u-joint #447 to go from a 10 bolt to a 14BFF. The two yokes are NOT the same. The #447 has 10 bolt size caps on one cross and 14BFF size caps on the other....like this one.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
