14 bolt tone ring
Discussion in 'The Garage' started by Hardcore, Jan 22, 2004.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Does anyone know what year chevy started putting a tone ring in the 14 bolt for the speedometer.
    Will the carrier out of a late model 14 bolt (with tone ring) fit into an older 14 bolt?
    /forums/images/graemlins/ears.gif
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I didnt even know GM had tone rings on the carrier. And its for the ABS. GM has their sensors on the wheels.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I've seen 14FF's through to '00 and none had a tone ring (all were drum brake type).
    Maybe this started with the discs? /forums/images/graemlins/thinking.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    GM uses a tone ring at the output of the transfer case to drive the speedo. Tone rings at each wheel are used for 4-wheel anti-lock brakes.
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I meant to say for ABS, oops!
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    even if you swapped the carriers (which you wouldnt since gm doesnt use tone rings on the carriers according to these guys), youd still have to drill and tap the housing EXACTLY where and how GM would have done it, to mount the speed sensor..
  7. u2slow
    May 9, 2001
    2,217
    BC Canada
    Many of GM's 4-wheel ABS systems used only three sensors - two front wheel sensors, and the VSS. Rear-wheel ABS used the VSS only.
    Have things changed with the 99-up Silverado/Sierra trucks?
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Dang! When did they cheap out? My '91 S-Jimmy has the tone rings at all 4 wheels.
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    The trucks have use 3 Sensors for as long as I can remember. Its just easier, cheaper and probably lasts longer on a work truck to have 3 sensors instead of 4 at all 4 wheels.
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    The first few years of 4-wheel ABS (91-93?), S-Jimmy, S-Blazer, Astro, and Safari got sensors on all 4 wheels.
    My guess is measuring individual rear wheel speed on a RWD is poor criteria for the ABS computer. Whereas the front wheels could lock-up individually depending on the traction.
    I'm sure it was a cost saver to do away with them. /forums/images/graemlins/wink.gif
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yeah, the ABS on this one sucked anyway. I disabled it years ago as it would pretty much turn the brakes OFF when trying to stop quickly on a bumpy road or loose gravel. /forums/images/graemlins/angryfire.gif
  12. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    So there was never a tone ring put onto the carrier of a 14 bolt, even the late models? The reason I'm asking is that a friend of mine wants to run a 14 bolt on his newer Dodge which uses the tone ring in the pumpkin for the speedo/odometer/ and tranny shift points. /forums/images/graemlins/ears.gif
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Correct, no tone ring.
