14 bolt torque spec's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tRustyK5, Mar 23, 2002.
  1. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    14 bolt torque spec\'s
    Yeah, yeah...did the search but couldn't come up with anything.
    I need the bearing cap torque, and the ring gear bolt torque if anyone has them off the top of their head.
    Also the axle shaft bolt torque I found in another post...seems high though. 115 lbs?
    Rene
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: 14 bolt torque spec\'s
    Rene, try these:
    Bearing caps...135 ft. lbs.
    Ring gear bolts...120 ft. lbs.
    Axle shafts...115 ft. lbs.
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    You da man Wes ...thanks!!! /forums/images/icons/cool.gif
    Rene
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    No problem. /forums/images/icons/wink.gif
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i need the tq for the hubs if you got them... this is all i could come up with... i know you TQ one, then back it off 1/8th turn then TQ the other with the lock washer in... i cant remember...
    grant /forums/images/icons/confused.gif
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    If you are talking about the spindle nut my chiltons book says 50 ft. lbs. on all 14 bolt FF's
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    time to re read your chiltons.
    zero preload for the bearings.
    that means no torque.
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Bette yet, just throw away the chiltons, spring the $30-40 for a used GM Service Manual, you will never regret it.
  9. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    so what is the torque for the spindle nut??
  10. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I pre-loaded mine to fifty, then backed it off and then back to 35 just like the front and have not had any problems yet. Correct me if Im wrong Please, but it has been working just fine for well over 5000 miles now. /forums/images/icons/crazy.gif
