14 bolt u-bolt bracket ?
Discussion in 'The Garage' started by chevyin, Sep 26, 2005.
  1. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    I have several sets of u-bolt spring brackets for 1 ton and am not sure what ones for the 14 bolt ff. I know I can order aftermarket, but was wanting to hang this afternoon. Anyone have A pic showing TIA :crazy:
  2. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    hummmm
    :doah: could this be the ones and I need to drill out for the bolt onthe 8in lift spring :mad: :eek1: :confused:
  3. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    your plates go on the bottom ot the axle . not on the spring.
  4. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Sorry about the pic size
    but I think you can see the bracket w/slider bar :crazy:
  5. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    I See
    But i'm still confused Do i need another bracket for the spring?
  6. sweetk30
    Nov 1, 2004
    25,539
    539
    the plate you have goes on the axle tube. then the square top ubolts go on the springs from the top. between the spring pack and the ubolts there is a little plate that helps center the ubolts. but this setup cind of sucks. best option is to do a ubolt flip kit. get round ubolts and new top plate better ground clearence.
  7. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    I got it
    Major mind fart here :crazy: . Thanks for the help :bow: :bow: :bow:
  8. sweetk30
    Nov 1, 2004
    25,539
    539
  9. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    one last ?
    The ubolts that came w/skyjacker lift kit look to be to large. I dont have original bolts as i'm installing the lift at the same time as changing to the 14 ff and dana 60. What do you think from pic? :doah:
  10. sweetk30
    Nov 1, 2004
    25,539
    539
    well thay are frigin huge. need to resize pics. but thay draw up a bit when you tighten them.
  11. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Now you know what it feels like from a bug's perspective. :D
  12. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    ORD to the rescue
    Thanks again i was being really stupid{happens all the time :mad: }. I found that steve has kit that includes new u-bolts. If the ones I have will work, well you can't have to many spare parts. :laugh:
