14 Bolt U-bolt measurements
Discussion in 'The Garage' started by greyhoundjc, Aug 3, 2006.
  1. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    I am going to have a local drive line shop bend me some new u-bolts for a 14 bolt axle that I'm about to install. When I bought the axle it didn't come with any. Does anyone know the exact measurements for the u-bolts that I can give to the shop? They said they will bend whatever I tell them to, but if there wrong I'm stuck with them :doah:.
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    3 3/8" I.D. Then just have them make them however long you need.
  3. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    5/8" x 3 3/8" x 10" stock
  4. goldwing2000
    goldwing2000 Guest
    That's what I used (with 6" lift springs) but they could have been an inch or two shorter. My deep socket was only grabbing about half the nut.
  5. greyhoundjc
    Jan 23, 2005
    127
    Georgia
    Thanks for the quick responses. I do have a 1" block in the back so the 10'' length will probably be fine. Did you measure the torque when installing them or just go as tight as possible?
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    axle tube dia for bend.
    length= axle tube dia + spring pack total thickness with blocks+ top or bottom plate + about 1" for the nuts at minimum.
    good rule of thumb is 1" extra on top of nuts for full nut contact.
  7. goldwing2000
    goldwing2000 Guest
    Always measure the torque and tighten in the proper sequence.
  8. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    Hey thanks for the new sig line:haha: :haha:
  9. sweetk30
    Nov 1, 2004
    25,548
    543
    no problem any time.:haha:
