14 bolt u joints
Discussion in 'The Garage' started by cluck, Jan 8, 2004.
  1. cluck
    cluck Newbie
    Apr 19, 2003
    3
    alright i keep chunking u joints what are you all runing i seached but no help its a 1/2 ton shaft to 14 bolt and 205 t case iv been using some basterd joint in the rear and stock 1/2 ton on t case any advice.
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Napa part #447 is what I used with no problems.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I am running the #447 Napa joint. Holding up good so far /forums/images/graemlins/thumb.gif
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    We need more info about your rig to answer that with any accuracy. What year? original rear diff? tranny? T-case??
    /forums/images/graemlins/confused.gif
  5. cluck
    cluck Newbie
    Apr 19, 2003
    3
    its a 79 k5 the 14 bolt and 44 are out of a 79 long wheel base truck the 205 is out of the same truck the 350 turbo i had laying at home it has 10 in super lift springs no blocks thats basicly the specks
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    3-3140, 1310 to 1350, which is Napa number 348.
    447 is for newer trucks with inside lockrings that use a Saginaw joint. My book says that this joint will NOT work for you, and you need the 348.
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'll second that! /forums/images/graemlins/thumb.gif
  8. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll third that...
    A Napa #348 is what I used to mate my 1/2 ton, 12 bolt d-shaft to the 14BFF. /forums/images/graemlins/thumb.gif
  9. cluck
    cluck Newbie
    Apr 19, 2003
    3
    thanks for the info ill see how long that holds up
