14 bolt Ujoint?
Discussion in 'The Garage' started by ssped, Mar 18, 2006.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I have searched and am not finding solid info on this. I did a 14ff conversion and need the corect ujoints to piece together. I have spent the day visiting local part stores and trying to cross reference #rs. I also went through their inventory at two places and the larger cap 14b joint will not fit on the smaller 10 bolt joint arms. The conversion page says 1310 and 1350 joints. I could only get one # converted and pulled. searching the data base is not coming up with more info.
    Help!!!!!
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    10b to 14ff?
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Napa u-joint conversion mark
    (1330)10b -(1350)14b = #447
    (1310)12b-(1350)14b= #348
  4. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    are the caps interchangeable on the 1330 and the 1350? or is the #447 a dual sised joint? I changed out the 10b.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    that 10b conversion joint is for a 14FF rear and your stock 10b driveline. The 1350 side goes to the rear and the 1330 side to the driveline.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Not to be a TIMMAY but the joint size is s44 to 1350 for a 10 bolt. The part number is right though #447.:D
    Ira
