14 bolt vs Eaton
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blzr83, Feb 12, 2002.
  1. blzr83
    blzr83 Registered Member
    May 11, 2000
    72
    eugene OR
    Hey, opinions on strength of an Eaton 1 ton rearend (12 1/4 inch ring gear) verses a 14 bolt. I know the shafts are about the same size (1.55 vs 1.5) but the splines are 17 for the eaton. On a K5 with a mild small block with this cause problems? Any thoughts? Thanks.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I don't see a problem with using it, just check to see if the eaton has the ratio you need. Just check the parts that are available for it, some parts maybe harder to get since they aren't used by GM for a long while, where as the 14 is still used today.
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the damn thing!!
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the 14 bolt is a BIG housing. the eaton is even bigger. if you can get a good deal on it hey, might be worth it. but the way i see it do it once and do it so you can have the ground clearance you need.
    just my thoughts.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  4. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    When you say Eaton are refering to the old FF Corp. 10 bolt?
    '70 K-20 San Diego, CA
    I know, I can't spell!
  5. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    They're talking about the axle that has a 3rd member like a 9 inch. It may have 10 bolts, I don't remember.
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps <a target="_blank" href=http://members.aol.com/fileholder2meg/projblazer.html>Clicky</a>
  6. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    just remember that the newest eaton is still a dinosaur. Parts availability for a 14 bolt is awesome compared to an old eaton unit. Its like an old big block versus a new small block. Id rather have a crate 350 than a 70's 454
    1986 GMC Jimmy 6" springs 3" body, 38/15.5/15 Swampers, 14-bolt FF rear, Dana 60 front, 1991 front-end.
  7. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    HU I don't know where you get your info but there is ton's of parts for the "70's" 454 and by the way it was the same motor up untill they changed to a one piece rear main around 86 and that was nothing drastic. Go check out some high performance places and see the parts you can get for a 454. Probably just as many as you can for a new crate smallblock.
    Corey 78K5
    350CI, TH350, 203, Dana 44,12 Bolt, 4"lift, Shackel Flip, Sawsall and 35" BFG's
  8. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    My '70 K-20 had a Corp. 10 bolt that I believe was an Eaton axle. It needed carrier bearings, bad. I got a 14 bolt and had it rebuilt for less than I could have rebuilt the Eaton. You can 't get lockers for Eaton axles any more. Locker for a 14 bolt: $300. Brakes are half the price on a 14 bolt!
  9. dysphemism
    Oct 26, 2001
    667
    Fremont, CA
    so corey youre telling me youd rather have a junkyard 454 in your rig without any mods than a new crate 350? hmm i dunno about that one. Im not saying modified Im saying a stronger engine isnt so strong after 30 years. Of course a 454 is more powerful when you rebuild it thats not my point. Im talking about how a seemingly stronger thing loses appeal after so long.
  10. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Couldn't you buy a junk yard 454 and rebuild it with performance parts for less than a crate 350 engine? My 72 402BB runs just fine, rather run that than a 350 anything. Anything you can do to a 350 you can do to a big block better :p
