14 bolt vs. rear Dana 60 ground clearance?
Discussion in 'The Garage' started by divorced, Dec 1, 2006.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    How much, if any, difference is there in the ground clearance of a late 70's 14 bolt FF compared to a rear Dana 60 from a late 70's Ford truck?
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I have 37" tires, and a late 70s 14BFF. You need a measurement?
  3. divorced
    Jul 20, 2004
    5,115
    Thanks, but I have a 14 bolt also. I'm wondering about a rear Dana 60 that I may use instead of a 14 bolt if the ground clearance is more.
  4. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Seems like the D60 stock would have better clearance than a stock 14ff. But after the shaving was done I guess the rest is up to you. Ive taken around 2 inches off my 14ff and its to my liking so far.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Don't know off hand, but just by looking at them, seems there would be alot more clearance with the 60 over the 14ff.
  6. mrk5
    Apr 20, 2004
    12,341
    1,046
    Northern Colorado
    You need to talk to jms, he runs a rear D60. Hopefully he'll see this thread.
    I know one thing to watch is the spline count. Rear 60s came with both 30 & 35 splines.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Another thing to watch with rear D60's is they are breakable where a 14bff typically is not. A guy I wheel with with an older Ford truggy has a D60 rear. He runs 37" tires & has snapped 2 rear D60 shafts. He now runs chromo's to help solve that problem. I have been told that the D70 is stronger & doesn't take up much if any more GC.
    If you are looking for strength & clearence check out a Sterling 10.25" from a Ford. They should offer better clearence then a 14bff & still be roughly the same strength.
    Harley
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    The only advantage I see with a Dana 60 rear is your gearing options are better.....I wish I had a D70 in the rear instead of my 14ff sometimes.
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Why? Gearing?
  10. 1977k5
    May 26, 2003
    9,995
    133
    30 spline is the FF (1.28" shafts, ~as strong as 1/2 tons). 35 spline is the SF.
  11. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Yes for gearing, the 14ff is limited in this area. I don't need streetable gears....
  12. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Some of the older ones were the coarse 16 spline units too.
    Rene
  13. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    A friend runs a D60 front and D60 rear with 7.17's and a dyno proven 500hp. the rear 60 was upgraded to 70 shafts and carrier I never asked much about it. but I've seen him beat the piss out of it for a number of years.....but now it sits idley by in a "morph" stage.....Like mine :doah:
  14. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Not including newerstuff, but the only 60 rear that had 35 splines were the GM 60 HD rears, vans and campers had them. But I think they are super wide, and wouldn't think the shafts would work in a stock rear.
