14 bolt weight question
Discussion in 'The Garage' started by Beast388, Aug 29, 2002.
  1. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The local U-Pull-A-Part is running a Labor Day special. For $35 you can have whatever you can carry out. I called to see if they would allow a dolly. They said no. I would have to physically carry it. So....my question is how much does a 14 bolt, complete with brake drums, weigh? I don't think I'll be carrying anything out that weighs twice as much as I do. /forums/images/icons/crazy.gif
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Not sure how much exactly but even with out the hubs and drums I can barely pick up one end to put on a cinder block to work on it. It took 3 of us to get it out of the truck and in to the garage with everything on it.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I think close to 300 pounds or more.
  4. BoyNamedSue
    BoyNamedSue Registered Member
    Aug 29, 2002
    6
    Tx
    Two guys could carry it out, just park close to the door. Or, you could grab it by the ebrake cable and drag that sucka out of there and leave pretty marks on their floor /forums/images/icons/grin.gif
    I guess if you get a piece of card board and put it under the drums, you could drag it out. I think they would rather you do that.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    I believe they are closer around 400 lbs. /forums/images/icons/tongue.gif
    I shipped a few of them in completely covered wood crates and they weighed around 525 lbs.
    I have been to a yard where they had a special of "pick, pull and carry." The one I went to required you to be able to CARRY the part(s) in your OWN arms or hands, nobody else can help you, and all you had to do was step over the gate line and drop it.
    If you are serious about getting a 14FF, seriously consider taking a short tow strap, like a tree saver strap, and have another buddy help you drag the rear to the gate and then tie the strap around the big hubs on each end. Try and carefully pick up the axle to where you can support it just enough to walk about 2 or 4 feet over the gate line and then drop it. You and your buddy can load it from there. /forums/images/icons/wink.gif
  6. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
    You could strip the brakes clean and leave the drums and all. Then just setup disc.
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Hope you are a big ole boy. /forums/images/icons/grin.gif
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    if the thing is complete hub to hub 400-450 pounds wouldnt surprise me at all. If they will let you do it, ditch the drums, them big b@stards weigh a ton. Even without them tho, you'd have to be a very large man indeed to move it out by hand.... then again, if u can somehow manage to do it, you'll get massive amounts of CK5-forum cool points from all of us! /forums/images/icons/shocked.gif /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif /forums/images/icons/grin.gif /forums/images/icons/wink.gif just make sure to post pics so we actually believe it! /forums/images/icons/tongue.gif
    J
  9. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Lift with your legs man /forums/images/icons/crazy.gif !
  10. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Does it need to be carried off the ground? Strap it to a backpack frame and drag it out. Wear a truss above your package, though.
  11. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i got mine in and out complete drum to drum by myself.i used my truck (about 40 inches to the tailgate) had to lift one end in then try and power clean the other end up onto it then push it in the rest of the way.they let me drive into the yard to pick it up though.it weighs about 400 pounds.if i could do it again i would have waited a day or two to get a friend to go with me to help,but i found it and just had to have it that day!! /forums/images/icons/laugh.gif
  12. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Find a set of wheels and just roll it out. /forums/images/icons/blush.gif
  13. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    Derf00
    LOL!!
    yeah its very heavy, took me and about 4 of my buddies to carry it out of my truck (6" lift) j-yard loaded with a fork lift..how nice of them.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, just make sure you have a hedge to catch it before it gets away... /forums/images/icons/wink.gif
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I recall reading in one of the 4x4 rags the 14 bolt fully dressed was about 530 lbs...
    Rene
  16. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Those 14bff are freakin heavy. Have at least you and 2 other people to help. When I got my 14bff back from the gear setup me and a buddy of mine carried it about 40 ft. That was a long 40 ft. We took it from the back of the pickup and walked it down my driveway. We each had a drum, and afterward we where pretty tired as that thing is massive. I would guess it weighed around 500lbs drum to drum. (keep in mind that I am 6'4" &amp; 265lbs &amp; my buddy is 6'1" &amp; 265lbs) A word of advice. Have a pickup with a low bed height and get some big friends to help.
    Harley
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    damn, u guys r f-in strong. LOL! I use a cherry picker and my d60/ff14b still dang near kicked my butt. /forums/images/icons/laugh.gif /forums/images/icons/grin.gif LOL!!
    J
  18. proyouring71nova
    proyouring71nova Registered Member
    Jul 17, 2002
    39
    CA San Rafael
    Wasnt sure but could you roll it out? I do it all the time just find to 8 lug wheels/tires and when you get to the gates just pick one side up at a time a trow it over the line. Just though I try. -max
  19. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Just remember, NOTHING is worth injuring your back for! 14-bolt rearends can be had almost anywhere for $150 if you look around. Is it really worth the risk of permanently injuring yourself for money? NO WAY! Be smart and save your money to buy one when you can get a hoist or enough friends to help and keep your back healthy. Wheelchairs aren't fun and I know!
  20. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    The wheelchair comment has me thinking. Get a friend with a wheelchair to carry one out on his wheelchair. If they don't let him do it, it's an ADA violation and he could sue the pants off them.
