14 bolt welding question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76K5, Nov 13, 2002.
  1. 76K5
    76K5 Registered Member
    Jun 23, 2001
    99
    North Carolina
    Hey everybody,
    I got some general questions about welding my 14 bolt. I am a novice but I can do simple welds. My first question is do I have to remove the carrier to weld it up solid. Also will I have to reset the back lash if I have to remone the carrier. On the 14 bolts how do you remove the carrier. I have access to a 100 amp mig, will this be enough amps to weld, or am I better off taking it some where to be welded.
    Thanks for the help, hopefully I can have everything ready in time for the snow. Thanks for the help! /forums/images/graemlins/usaflag.gif
  2. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    You'll need to remove the carrier. To remove carrier take rear end cover off and drain fluid. Mark each bearing cap for which side they go on and remove them. Make a mark on the collars that adjust backlash so you can return them in the correct spot then count and write down how many turns you make to get the carrier out. Take ring bolts off and weld away. Put carrier back together and back into housing. turn collars same amount you took out and line up with you marks. Replace caps to correct side. Install pan and fluid. Have fun.
    I hope that covers it about right.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You need a bigger welder for this job...pm Jethro for pic's and info on welding one of these up. He's done a few by now.
    Rene
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    And someone correct me here if I am wrong, but I don't think you want to drive this thing with a welded rear in the snow, you're better off with an open diff.
    That way you might go nowhere, but with a welded rear you could get nowhere FAAAAASSSSSSSST. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Snowy streets I never had a problem, in fact I felt I had more control. Snowy off-camber trails were another thing though...welded and chained would be much better./forums/images/graemlins/grin.gif
    Rene
  6. 76K5
    Jun 23, 2001
    99
    North Carolina
    Thanks guys, if I take the the carrier out and take it somewhere to get welded what do you thinl it would run me.
    Thanks for the info! /forums/images/graemlins/usaflag.gif
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Maybe if you send the guts to Jethro he'd weld it up for you? The carrier itself doesn't get welded at all...
    Rene
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't think he wants to send it all the way to CA to weld the gears, he can do it locally much cheaper.
    /forums/images/graemlins/thumb.gif
