14 bolt went in......
Discussion in 'The Garage' started by BigMac, Sep 22, 2002.
  1. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    After much sweating and back straining (thanks again Ray) my 14ff w/ disks is hangin under my truck /forums/images/icons/grin.gif I now have only 2wd cus the gears don't match and some really killer milage which suprises me quite a bit.
    When I first connected the brakes and blead out the air through the original praportionong valve the rear brakes didn't work at all. I had the red light od death on the dash and you could hand turn the hubs with the brakes pressed hard. They do work now without the praportioning valve but something isnt right....
    I have to get the front end parts in and try some new front rotors and maybe bleed the front again real good and see if it improves.
