14 bolt wheel beAring preload??
Discussion in 'The Garage' started by chulisohombre, Apr 1, 2003.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    when i try to tighten the bearings it gets tight in between the grooves where you would put in the key to hold the bolt in place.when i tighten it to the next hole it seems that the preload would be to tight,but when i back it off it seems that the next looser hole would be too loose and not have any preload on the bearings.should i just tighten it to the next tighter spot on the keyway for the correct preload??thanx
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Just a thought, but try swapping the sides that the preload nuts are on. That is, put the one on the right side of the truck on the left and vise-versa. It might make enough of a difference to get them to line up. </font>
  3. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i already tried with the same results.so next question.how much force should it take to turn the wheel by hand if the preload is right?there is slight resistance,but it doesnt feel binding.its not locked up or anything.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If the bearings are new I'd go tight on them, if they're used go loose. Either way check them after a 100 miles or so. </font>
  5. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    like i said they feel way loose if i put it back to the next spot.it does not wobble but the hub spins real free like there is no pressure being put between the bearing and race
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Sounds like you just answered your own question then. /forums/images/graemlins/thumb.gif </font>
  7. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i guess i'll just have to try it and see what happens.thanx for trying to help
  8. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    remember to squirt some 90 weight in there to prelube the bearings I didn't and i replaced bearings in about 50 miles
  9. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i squeezed some bearing grease in there before i closed it up.if i had put 90 weight in there it would have leaked out and probably not seal the axle very good when i put the silicone on the shaft.someone said on anether post that it is good to prelube it with grease so that you know it has some in there.then it dissolved as the gear oil runs through it.how does the gear oil get down to the end of the axle.looks like the axle shaft is pretty tight in there.does it have a hole machined in or something so that the gear oil flows freely?
