14 bolt width question...
Discussion in 'The Garage' started by k5-newbie, Feb 3, 2005.
  1. k5-newbie
    k5-newbie 1/2 ton status
    Jun 19, 2004
    399
    Huntsville, Texas
    are the spring perches on all 14 bolts the same width or is there a 14 bolt that will bolt right in under a blazer? I know the one out of my 1 ton srw will not?
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Short answer is that 3/4 ton 14 bolts will bolt in, and one ton won't.
    Slightly longer answer is that you ALSO want an SRW axle; there were 3/4 ton duallies, so be sure not to get one.
    -- A
  3. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    is the 3/4 ton axle as strong as the 1 ton? that may be a stupid question but I am a newb at this 4x4 stuff :)
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The only difference between a 3/4ton and 1ton 14FF is the spring perch placement and the brake shoes.
  5. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    thanks guys...thats a huge help. now if my TC springs would ever show up:woot: :whistle:
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Not to hi-jack but what about a van 14-bolt will it bolt right in or do I need to change the spring perches?
  7. k5-newbie
    Jun 19, 2004
    399
    Huntsville, Texas
    not sure on the spring perch ? but i think the van 14 bolt is about 3" wider than the others.
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Van has wider perch spacing... nearly 50" IIRC.
    With the pickup variety, the other difference between a 1-ton SRW and 3/4-ton SRW is the size of the drums.
  9. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    perches will need to be relocated. Just went through this on mine about 2 months ago when I got my van width. Van width axles are roughly 3 inches wider than a regular. There is another post floating around here that has the exact measurements of all 14 bolt axles.
    Here it is............. http://coloradok5.com/forums/showthread.php?t=127970
