14 bolt with cadilac calipers.help wes if youve seen this.
Discussion in 'The Garage' started by chulisohombre, Oct 3, 2002.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    ive seen 2 different write ups and neither of them said how to use the cadi calipers.i need to know how this will work and what i will have to do to use these.im in PA and have to pass inspection whick means for legality i have to have a functioning ebrake.i dont wantr the d-shaft mounted one so the cadi ones is the only way to go.anybody wo uses these let me know how.thanx
  2. Robbie6987
    Robbie6987 1/2 ton status
    Jul 16, 2002
    111
    killeen TX
    Re: 14 bolt with cadilac calipers
    May sound dumb but would a line lock work?
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Line locks work with the hydraulic system, inspections want a mechanical e-brake. </font color>
  4. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i got to have a functional mechanical ebrake for to pass PA inspection to keep the beast road worthy.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    damn good question...
    ...i'm dying to know the answer also.
    i want to do the same thing... maybe use caddy calipers and still use the cable ebrake instead of a driveshaft mounted one.
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    what he said! /forums/images/graemlins/confused.gif
  7. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    help somebody.putting this in in a couple of weeks.gotta know how to do it so at least i can get some ideas.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Damn! I have never had a chance to mess around with the Caddy calipers yet. /forums/images/graemlins/frown.gif
    All I have for my records on the Caddy calipers are the brackets, springs, etc. part numbers that you can buy brand new to make them work.
    I believe if you got these brackets, springs, etc., you would still need to fabricate another bracket to the housing tube to hold these other brackets.
    These brand new brackets and springs are just the same stuff that come with the calipers when you pull them off the junkyard car. I've got the part numbers for them because we don't have junkyard Caddy's around here. So, if I were to use these calipers, I would go to the parts store and get rebuilt units. This is where the brand new brackets and springs come in handy. /forums/images/graemlins/wink.gif
    So, don't know what to tell you here. /forums/images/graemlins/frown.gif Sorry man!
  9. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    do you have any ideas on how these would work?part numbers would probably help a lot anyways.i can get the calipers for 85 apiece new,but i didnt know they needed a seperate bracket.how does this bracket work?is it just to hold the ebrake cable in place or????
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    This is where I can't really help you until I have some calipers and the brackets and springs on hand to visually see what I would be dealing with. /forums/images/graemlins/frown.gif
    From what I understand, the new brackets are the pieces that bolt to the calipers only. You still need to fab a piece to the housing tube. This piece to the housing tube is also the part that I think most people have trouble with since 90% of the time I hear or read about people having trouble with the Caddy calipers. I seriously believe the problem lies within the proper location for the bracket on the housing tube. It has to be perfect to have the proper slack and tension on it in order to work like the drum brake type.
  11. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Shawn Spickler wrote the article at Offroad.com. He is a member here as Shawn . The write-up is no longer on offroad.com /forums/images/graemlins/confused.gif. Maybe he can help you.
  12. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    thanx ill try and email him and se what comes up.
  13. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    wes i guess i'll have to just get the calipers and try and fab something that'll work for me.thanx for the reply anywho. /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
  14. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    ttt please help?
  15. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Heres the article from off-road.com. The people that took that main page over from Shawn screwed it all up and got rid of all the tech articles mostly, but I still know the link to the main reviews page that has them all even though they took the links off the main chevy page /forums/images/graemlins/thumb.gif
  16. chulisohombre
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    thanx willyswanter.first person to have the link to that page.ive had a couple of people tell me it was shawn who did the article but noone knew the link.i tried also to get ahold of shawn but no response.at least now i have a better tech article about the setup.thasnx agin /forums/images/graemlins/thumb.gif
