14 Bolt Yoke Question?
Discussion in 'The Garage' started by 79Stomper, Jan 2, 2005.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Anyone ever convert their yoke from the strap type to the U-Bolt style? Anything special you had to do? I see that the back of the yoke isn't quite flush so I am thinking grinder maybe.
    Why do I ask you say? I broke a bolt off in my yoke today and had to drill it out so now going to put in the strap type, until I can upgrade the yoke with one from H.A.D..
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I think there was just a post about this but what I got was that if you grind the yoke it weakens it but I just dont see how a little bit of metal will make it fail, your only other option is to get a 1410 yoke from HAD or a place like that which is set up for the u-bolts :xmas:
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I did the same thing last year. I ground on the backside of the yoke so the nuts would sit flat...really didn't have to take much off, and I have had no problems with mine. There is still a lot of steel there it might be weaker, but unless you are puttin down some serious HP or doing 4500 RPM clutch drops I think it will be ok.
  4. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Which U-bolts did you use to hold the U joint on there? The cpu at the parts store had a u bolt type for a K-20 and done a cross reference with the joint and came up with one off of the K-20 and should fit. Only thing I am worried about it the length of the u bolt going through the yoke itself. Ordered it and going to try it tomorrow when it comes in.
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I'm interested in doing this too. you guys got the part numbers for them?
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I got some from a farm supply store not sure what they were for, but they work:D
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I have seen them in the HELP section at the parts store but havent tried to fit one with a 1350 u-joint.
